Use this command to turn on SNMP trap support for L3 VPN.
| vr_name | Specifies the name of the parent VR where this RFC 4382 scalar is applied. If VR name is not provided, then this command is applied to the VR in the current context. |
Enabled.
Use this command to enable generation of L3VPN SNMP traps—mplsL3VpnVrfUp and mplsL3VpnVrfDown. These trap notifications are sent under the following conditions:
The following example enables L3 VPN SNMP traps support on the switch:
enable snmp traps l3vpn vr vr-default
This command was first available in ExtremeXOS 15.3.
